staticV3
- Joined
- Aug 29, 2019
- Messages
- 8,017
- Likes
- 12,861
Your music players are all using the Wasapi Shared or the Direct Sound API, in which case all content will be resampled to the sample rate that you select in the Sound Control Panel.Thank you for your response . The only issue I am having is the D100 does not show the higher rez # when i play Amazon ultra HD . It will always show the same setting that i set on my computer which is 44.1 ....it never changes even when I choose a higher rez even on Tidal and Qbuzz . I even tried running with Foosbar settings and still the same .Not sure what I am doing wrong
You can go there, set your DAC to 384k and the DAC's display will always show 384k.
If you want to avoid that resampling, then you have to use a music player with Wasapi Exclusive or ASIO API.
Foobar can do both, if you install the right add-ons and select the API in the Output settings.
