Soncoz LA-QXD1 Balanced DAC Review
mt196
Rome, Italy
There's actually no downside to higher bit depth it won't have any negative effect. But 24-bit should suffice, it allows up to -144dB DR... ;)
Technically the more khz the more audio band you have so, since you cannot hear above 20khz at best, you are just processing a lot of useless informations above 44.1khz that is the double of 20, that was what I wanted to say. About bit depth, the downside of having it too high is that the DAC chip will be more stressed and if you look at some datasheets they show that distortion rises with the rising of file complexity, so I am for keeping things simple 16/44.1 is the best overall, and 24/192 is for me the best compromise since a lot of music is better mastered/recorded on SACD
JIW
Germany
I have an early 2015 retina MacBook Pro running macOS 10.15.5.
I also don't get sound from Chrome at 768 kHz. In Firefox, I do get sound but it's quite distorted.
Anyways, there is no reason for you to set the sample rate to the DAC's maximum. Since all the components above half the original sample rate need to be filtered out for accurate playback, all you end up doing is using the oversampling algorithm of macOS's Core Audio rather than that of the DAC. Thus, it is likely best to set the sample rate of the DAC to the original sample rate of what you want to listen to.
Regarding the number of bits, Audio Devices tends to only show the maximum number of bits for USB devices. If the DAC's sample rate is that of the audio file and the volume is set to full, it will not add or subtract anything, i.e. the least significant bits are all zero.
First posted here.
Veri
24/44.1 is objectively better though, 16-bit files will simply losslessly be padded and you'll get benefits of 24-bit noise floor, much larger digital volume headroom and better jitter: 16-bit async connection tends to have substantially more jitter than the same thing transferred over 24-bit.
So no, I wouldn't recommend 16-bit. I mean it's fine but it's not ideal. If you were to do the same argument against 32-bit then yeah I'd agree that there's no real point but well, if people want to use that... it's also fine. I'm personally always on either 24/44 or 24/48.
Brab
I just plugged and played my DAC. It seems to be using a generic Windows USB driver. Is there any advantage to using the updated USB driver referred to above?
Veri
Windows and most other OS have a general purpose driver. It is fine and has proper WASAPI support etc. If you need ASIO however for whatever reason, you will need the driver :)
In addition to what @Veri said, I'd imagine the official driver probably also includes DSD support if that matters to you.
NCX
Is point #4 true? (pressing F to doubt)
LA-QXD1 can be easily used in pure DAC mode,to do so, simply raise the volume to the maximum.
Source=Hifi Go. This claim is absent from the official LA-QXD1 manual and product page, and the higher end SGD1 as well
This is a very important feature to me since I plan on connecting the XLR out to my Violectric V281 clone, the Accurate Audio HPA-A281 and do not want to double amp my amp. I know the Schiit Modius has a pure DAC mode, but I want the better Optical input performance since both units are the same price.
Screenshot_2020-07-17 SONCOZ LA-QXD1 DAC Balanced XLR Outputs ES9038Q2M 32-bit 768kHz DSD512 X...png
ChrisUK
I had this dac on trial for a few days. It was OK but nothing special IMHO. In other words it did nothing bad or anything exceptional. A good choice for a low priced dac, but don't expect it to sound any better or different to other circa $200 dacs.
turbotuff
So what do you feel is the better DAC in the $200 price range?
Purité Audio
Industry Insider
Barrowmaster
London
ChrisUK
The problem is you said to be equal to other 200$ DACs while I can show you a lot of DACs with higher prices that perform way worse than this
But do they sound worse? Measurements are only one metric to consider.
Purité Audio
Industry Insider
Barrowmaster
London
Measurements completely characterised the dac, there is nothing else.
mt196
Rome, Italy
Since it is a "simple" DAC, measurements are very precise in characterizing its sound. But yes, maybe if someone prefer a DAC that change the original sound in a smoother one or a warmer one, than you are not looking for perfect measurements and thus they do not matter so much for that people, but I like hi fidelity, thus I like a audio chain that reproduce exactly what the artist created, leaving the coloration of sound to speakers and headphones that are waaay more controllable and swappable if you don't like their sound without having to worry about all the colorations going on due to amp and dac
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
What makes a DAC special?
Are you expecting it to alter the original signal, to somehow make it sound different from another (transparent...competent) DAC?
I'd rather leave the adding or subtracting out of the DAC's job description, other than the math it needs to do to get it as close to the original as possible.
somebodyelse
There are two firmware variations available. The default one starts with a low volume for safety when people use it connected directly to a power amp. The alternative one starts with maximum volume for those who want to use it as a pure DAC and have volume control done by preamp, integrated amp or whatever. You can load whichever firmware better fits your needs.
Reactions: NCX
