Airplay update. Using Amazon, it is showing 24 bit/48khz in the app but my DAC shows 44.1khz.
It’s 16/48 via iOSAirplay is currently limited to 16/44.1
Wiim Home Deezer, iPhone 7 as remote, showed FLAC earlier in the day??It’s 16/48 via iOS
Deezer is a little messed up, but it sounds okay. Ending its' trial soon, back to lossy AM, maybe I can't tell the difference anyway.Try a different source
We need a summary list
When I say Airplay is limited to 16/44.1k - I'm talking about WiiM's Airplay implementation at the moment, not Airplay in general.It’s 16/48 via iOS
Audirvana can use Airplay 2 off MacOS (in addition to uPnP) to communicate with WiiM. When I send a 24/48 file from Tidal to WiiM, Audirvana reports that it is sending at 24/44.1 file through Airplay 2. It's possible, as you say, WiiM then truncates the extra bits to 16/44.1, but WiiM is reporting to Audirvana that it can receive 24 bit files. Indeed all MQA files from Tidal whether 192Khz 96Khz etc are sent as 24/44.1 to WiiM over Airplay 2 by Audirvana.Airplay is currently limited to 16/44.1
WiiM have told me they are seeking approval from Apple to support 24/48kHz.
Much respect to the WiiM team.
They are pushing along, step by step.
For Amazon use though, the coming UHD support update might be of more interest to you.
Have you asked WiiM to be on the whitelist? to beta test
WiiM can receive 24 bits from Audirvana - via UPnP. That's a completely different protocol to Airplay2.Audirvana can use Airplay 2 off MacOS (in addition to uPnP) to communicate with WiiM. When I send a 24/48 file from Tidal to WiiM, Audirvana reports that it is sending at 24/44.1 file through Airplay 2. It's possible, as you say, WiiM then truncates the extra bits to 16/44.1, but WiiM is reporting to Audirvana that it can receive 24 bit files
That is very low. CD quality is ~1400kbpsNot completely sure if I did it right, but the WiiM 5G bandwidth seems to be about 115kb/s
You can't trust anything in the Amazon app other than "track quality". Everything else in that screenshot is bollucks (not your fault)Airplay update. Using Amazon, it is showing 24 bit/48khz in the app but my DAC shows 44.1khz.
The ios/android app has got worse in that respect, around the same time as they introduced Dolby Atmos/3D tracks. I've even seen the device capability change between tracks which makes no sense at all...You can't trust anything in the Amazon app other than "track quality". Everything else in that screenshot is bollucks (not your fault)
Hopefully one day "track quality" matches what DAC input shows.
It's hilarious that none of these huge companies have got it all worked out.The ios/android app has got worse in that respect, around the same time as they introduced Dolby Atmos/3D tracks. I've even seen the device capability change between tracks which makes no sense at all...
Spotify Connect is superb but 'limited' to lossy.
Tidal Connect is very good except stuck with fake hi-res MQA lol, just give us the real thing. If they dump MQA , this is the best of the bunch.
Amazon is a complete joke, not sure where to start but I'm sure you already know.
Apple could update Airplay to support 24/192 but haven't yet. For now it's a mess. They are closest to possibly get it perfect.
I reckon by the end of this year one of the above will be 'sorted'.
Who will it be ! Who knows. Maybe YouTube Music comes out of nowhere and does it properly. Although Chromecast at present is not gapless.
Using Tidal MQA, Audirvana sends 24 bits up to 192 KHz to WiiM via uPNP. Using Audirvana with Airplay 2, MQA is fixed at 24/44.1WiiM can receive 24 bits from Audirvana - via UPnP. That's a completely different protocol to Airplay2.
WiiM Support told me yesterday Airplay right now is limited to 16/44.1 in WiiM Mini and they are applying for approval for 24/48k.
Thanks for testing.
But see post #980 above by @Ralph_Cramden . It can be a bit tricky to use this bitrate data.
Everyone needs to ask WiiM Support to add bitrate data to their Home app, so there will be much less guessing.
