Yamaha A-1 Vintage Amplifier Review
This is a review and detailed measurements of the Yamaha A-1 vintage integrated amplifier. It is on kind loan from a member. He tells me that it has been serviced and restored a couple of years ago. The Yamaha A-1 came out in 1977 during a competition to produce the best spec audio products.
Most of the controls are hidden behind a drop down door:
On touch of the volume control and you are taken back to golden age of such mechanical controls. Boy, had I forgotten how good these used to feel compared to garbage that passes from mass market audio companies these days.
The buttons have the most solid feel, reminding me of ones we used to put on pro video products. Solid as a rock with positive feedback.
The "DISC" button is the equivalent of "pure direct" on modern AVRs and such and bypasses much of the circuitry internally. Alas, it is designed for LP playback to the phono equalization remains in the path so I did not test it for this review (may do later).
There are tone controls (but no balance). I set it to off of course for my testing.
The manual hearkens back to an area when performance indeed did matter including measurements that remind one of chip specifications:
The rest of the manual is full of diagrams clearly showing circuit flow and topology of various stages. Shame on the audio industry for forgetting its roots.
The unit is for Japan market and as such, is rated at 100 volts. To test it here in US, I used a variac to dial down the voltage to 100. This is a beefy 2000 volt-amp unit so should not impede power. But may be responsible for some mains leakage (which I could not lower with playing with grounding).
Speaking of beefy, the A-1 is massively heavy on the left side, sporting two independent transformers, one for each channel.
The components inside are quite rusty as you may be able to tell, having enjoyed some time in a damp shed no doubt. Despite that, at no time did the unit complain by shutting down or anything. It does have a high pitch whine if you stress it though or during warm-up.
Those metal components in the middle of the heatsink are the power transistors using the "TO-3" package. During that era, anytime you saw these transistors you knew that good money was spent on the components. TO-3 transistors with their large metal enclosure dissipate heat a lot better than the TO220 and other alternatives. Alas, they cost a fortune so they were phased out over time.
The power supply capacitors are top-brand japanese Nichicon. They did not look very fresh to me though even though they were supposed to have been replaced two years ago. Wonder if they used older parts.
One of the things I did not like was the flimsy speaker terminals that you could barely get to tighten on bare wire. I soldered my wires to give them more girth and they still barely held on to them.
Pre-amplifier Audio Measurements
The Yamaha A-1 has preamplifier out but unfortunately no input to the power amp. I thought we start with how the preamp perrforms then before testing the whole unit:
Looking to the right of our 1 kHz tone, we see that the only harmonic distortion visible is the third harmonic at -110 dB! That is very good.
Alas, SINAD which looks at both distortion and noise suffers from the power supply spikes, lowering to 90 dB or so. Still respectable but a loss of 20 dB.
FYI, 1 volt is the maximum usable input on this amp. Going beyond that severely clips. Rated input is actually much lower than this and being before the CD era, this is understood.
Amplifier Audio Measurements
I set the gain to 29 dB using the volume control and ran our usual dashboard at 5 watt into 4 ohm using a 1 kHz tone:
I should note that I had to let the unit come up to temperate at 9 watts or so for a few minutes. Prior to that one channel had a lot more distortion which gradually reduced. The A-1 has massive heatsinks and the temperature sensor is placed on the opposite side of the transistors, requiring a while for it to get a more accurate snapshot of the transistor temperature to set bias.
Once there, we see again that our harmonic distortions are quite low at below 100 dB. What is there are power supply components which heavily derate SINAD. As is, the A-1 doesn't place very high in our list of amplifiers:
Note that from audibility point of view, the power supply spikes don't matter much since our threshold of hearing is quite high there. So this is a case of SINAD showing us something that is not very representative of audible performance. Alas, we have made our bed and have to sleep in it with respect to SINAD. :)
Drilling more and only looking at harmonic distortion we see a far prettier picture:
Distortion products are at or below -105 dB which again, is very good. Our threshold of hearing is only -115 dB or so meaning these distortions are all but inaudible.
Alas, noise is the problem as we can see with no input to the A-1:
How much of this is due to age of this unit is hard to say. Perhaps whoever restored it did not pay enough attention to power supply output. There is no equivalent measurement from Yamaha to know for sure. The kind of FFT analysis we can do today would have been unheard of when this device came out.
The higher noise floor hurts baseline performance at 5 watt:
The owner told me that the SNR is around 112 dB or so. Clearly we are missing that by good bit but what is there is good enough at full volume to clear the 16 bit CD hurdle.
1 kHz spectrum naturally shows a very clean output:
THD+N versus level and frequency is I think the cleanest I have seen:
Yamaha A-1 Stereo Amplifier THD vs Frequency vs Level Audio Measurements.png
All the lines land on top of each other as if the frequency doesn't matter. Note however that due to high noise floor, we don't get to see the true distortion metric so perhaps that is helping here. Yamaha measurements show more of a differentiation so perhaps our sample unit is noisier than it should be.
Let's look at our power output versus distortion and noise into 8 ohm:
We meet the specification for power and do better in distortion by a mile.
Here is the same for 4 ohm load:
We clock a lot better here beating both power rating and distortion level Yamaha used.
I did not attempt to measure peak or maximum power as these keep the amplifier at full power for a while and I did not want to chance damaging the unit. Likely could have handled the load but I just did not want to take a chance of blowing the output stage and searching for devices that may not be manufactured anymore.
The stories of these hero amplifiers of the 1970s beating the distortion devil seems to be true. The Yamaha A-1 aces such tests, beating vast majority of amplifiers today and putting many to shame big time. What keeps it away from achieving top status is the high power supply noise. As mentioned, I am not sure if that is due to the sample I have or typical of the unit. With that included, our state-of-the-art amplifiers like Hypex/Purifi and Benchmark AHB2 provide a wide gap in performance.
I don't know how much these units go for but if they are reasonable in price, they would make a good alternative to modern amplifiers.
As always, questions, comments, corrections, etc. are welcome.
Seeing the vintage amplifier, the panthers are demanding vintage clothing to fit in! I think they have a point so like to get them all new, 1970s era outfits. So appreciate kind donation from you all using : https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Tks
So 50 years ago we have essentially more competent design than the majority’s end of the amps we see today, not only that, but the performance could have been better perhaps if the unit wasn’t so aged?
Mains noise seemed to be the issue here from the most part, and it seems there are products out there even with noise taken care of, sometimes don’t even match this things’ performance.
Aside from a few companies like Benchmark.. and aside from having removed measurement data in their manuals, what exactly have Power Amp makers been doing for the last half decade just wondering?
RayDunzl
Central Scrutinizer
Riverview FL
What's Consumer High Tech today?
Cell Phones
Personal Computers
TV
Video Games
Internet
What was Consumer High Tech 50 years ago?
Stereo Gear
Color TV
Touch Tone Dialing
Fluffy
For me that looks like another proof that audio electronics had reached their technical peak a long time ago. Making transparent amps/dacs/formats is not that hard or expansive, and any additional real improvement in capabilities is currently down in the realm of inaudible levels of resolution. What's left for Hi-Fi manufacturers is either trying to build amps that are intentionally not transparent, and by doing that they can claim their gear have a sound signature of its own and charge a lot for that privilege. Or packing as much features as they can to justify the high cost.
The audiophile mythos of "the sound of the electronics" is fueling a stagnant industry that keeps churning out sham "innovations" to keep companies afloat. I wish there could be some endgame solution of a product that will cover all possible needs in the audio field, so all that money and engineering prowess would go to benefit more important industries for humanity. Renewable energy maybe? :rolleyes:
Zaki Ghul
Speaking of vintage stuff, did anyone do measurements on the Sony DAS 702es (1985) or the DAS 703es? It would be interesting to see where they would fall on the contemporary dacs list, would they be dead last or beat some of the worst offenders.
Prices for these things is so high these days. I can only find the 703es on ebay and the guy wants $1000 for it!
Zaki Ghul
I'm going to try to get one from Japan's Yahoo auction site once I have some extra to spend. Usually they go for much less there. I have the matching cdp 650esd and would like to complete the look.
pozz
Слава Україні
Editor
IIRC, the original AHB produced in the 1980s for broadcast studios had roughly similar distortion performance, but output only 35 watts.
JohnYang1997
China
Even according to manufacturers' specification, the distortion is never as low as -100db at 1000hz and it's only lower than 0.01% at 20khz. There are always people talking how many zeros those 70s manufacturers got. It's completely utter bullshit. It's barely blameless in standards now(omitting the ps noise).
restorer-john
Huh?
Look at the graphs. Line (tuner) to speaker out. It's pretty clear.
JohnYang1997
China
Huh?
Yes. Still higher than -100db at 1k and just below -80db at 20k. Nothing wrong with it.
I was talking about people who said there are zillion zeros or at least 0.0000x% distortion from the 70s. I was always like wtf?
GrimSurfer
Aside from a few companies like Benchmark.. and aside from having removed measurement data in their manuals, wha exactly have Power Amp makers been doing for thr last half decade just wondering?
Yes. Or... a 42 year old unit stored in a damp shed and sporting its original filter capacitors has a measured SINAD performance comparable to that of a new Crown XLS 1502.
Makes one laugh...
JohnYang1997
China
Two reasons.
1, they also people are after audiofool bs and snake oil.
2, better performance doesn't bring audible improvements so the focus on the look and branding.
MZKM
Land O’ Lakes, FL
HiFiShark shows them selling for $200-$400 usually.
From what so can find, when you adjust for inflation, it’s MSRP was ~$2000 when it was sold.
