Forum Software Upgrade!!!
Sal1950
The Chicago Crusher
Central Fl
I noticed that if I set the fonts back to default size the avatars appear normal but enlarging them with Ctl+ disturbs their proportions. Never happened before here or at any other sites?
Sal1950
The Chicago Crusher
Central Fl
Thanks. That must not be it as I just tested it with Edge and Firefox browsers and it looks fine.
Can you do a refresh on this page? On Windows it is control+F5.
OK, now the effect has disappeared?
RayDunzl
Central Scrutinizer
Riverview FL
I look divine to myself, but Sal is not seeing me at my best, for sure...
Sal1950
The Chicago Crusher
Central Fl
Ray there's something serious wrong with you.
And I'm not talking about the avatar. :p
Apesbrain
East Coast, USA
Looks good! Can you make the "Wanted" box at the top of the page closeable? It takes up a lot of screen on mobile. Thanks.
jaynyc
New York
big improvement.... the threads which are the hardware reviews with charts now render full width on mobile.
thank you!
OK, I just made that change. Let me know if it doesn't work.
RayDunzl
Central Scrutinizer
Riverview FL
It works here on desktop.
Sal1950
The Chicago Crusher
Central Fl
OK, home page is up! It is much more slick looking than before. :)
There's so much good information on that page. It would be great to have some sort of index to what's available. Forever clicking on Load More to create the ever larger page can be a bit frustrating?
Chris Prosser
Seattle
Looks much better on Mobile, especially verical layouts. In regards to New Posts, I found New Posts under the hamburger menu on my phone. Not sure where on desktop.
I’m currently grinding though GDPR compliance at work. Wish we could just upgrade to fix it :).
Sal1950
The Chicago Crusher
Central Fl
andrew
What is the best path to using on a mobile device (iOS)? I’ve never got ASR to work with Tapatalk and wondered if there was another app that could bu used with this framework?
Soniclife
On android I use the url for New Posts, I find it works very well. Also have a play with the forum themes to see which works best for you. I don't see why it should be worse on iOS.
Just browse it as you do on the desktop. This new version is highly optimized for Mobile and will reformat the site as needed to match the resolution and size of the mobile device. You should not need any special app.
