totti1965
Hey,Sorry if it sounds like a stupid question lol. The reason I ask is I don't quite understand everything about how the power supplies affect the sound. I just want good quality sound without distortion. Will the 32V give me good clear sound as long as I keep it low volume?
For nearfield stereo you would play very very Loud - even with 1 Watt: Sensitivity is 79.4 dB / Watt an 1 meter. So in stereomode with 2 x 1 Watt you will reach 85.4 dB. This is VERY loud!
With the 34 Watts per channel at 8 Ohm, which the Fosi V3 -32Volt is able to serve, You will get even 15 dB more: each speaker would get 94.4 dB In Stereo a total of 100.4 dB. The Problem is: You will not reach more than 86 clean dB with one of these tiny speakers.
So the 32 V Device is far more than enough!
By the way: The Dayton is fantastic with a little bit of equalizing
Spinorama.org shows us exactly, how to do this (a bit more accurate than the "quick and dirty" Equalizer suggestions of @amirm :
Dayton Audio MK402X
AutomaticEQ (IIR)
Set preamp gain to: -2.9dB. |
