Marantz AV8805A Review (AV Processor)
MacCali
Yes that is specific to your avr, speakers and your listening habits (spl requirement and distance).
To be clear, like power amp output, it can also be said that for preamp output, the higher the better. It is however, important to realize if you don't ever tap into outputs (preamp and/or power amp), you won't benefit from it in terms of audible sound quality. I only ever used about 0.2 to 0.5 WPC average, or up to 50 W (8 ohm) for the 20 dB peaks in some contents I might play when listening to music in stereo, but the amps I use are rated between 50 (the weakest one) to 350 W (the strongest one), not counting the 5 W DIY amp. I have used all of them to drive my speakers and they all perform the same sonically speaking with the exception of the 5 W amp.
The answer to your question about preamp output (aka pre out) voltage requirement depends on at least (in case I forgot some) the following:
- you power amp input "sensitivity", or "gain"
- your speaker sensitivity 2.83 V/m is preferred, if given in W/m then you have to consider the impedance, example for 4 ohm speakers, at the same voltage the power will be 2 W, and for 6 ohm speaker it will be 1.33 W
- your spl requirement, this is important when you consider the fact that for every 3 dB increase, your power amp requirement will be doubled and your preamp output voltage will have to increase by square root 2, that is about 1.414 times.
- your listening distance from speakers. Without factoring room gain, every time you double the distance the spl at you listening position will be reduced by 6 dB.
Assuming you don't sit further than say 4 meters, in a medium to medium large room, you will not have to worry about the above if you stick with preamp output >2 Vrms and power amp output > 200 W. Again, generally the higher the better..., there are always exception to the rules such as for someone who has truly hard to drive speakers..
Lastly, you seem to always referenced to "input sensitivity", from your previous posts/questions but I am not sure if you understand fully the relationship between "input sensitivity" and "gain".
In my opinion, gain is preferred because it is easier to understand. It is the ratio of Output to Input, the only slight complication is that amplifier gain is more often expressed in dB that is based on the "log scaled". The formula to convert from Vout/Vin in multiples to dB is 20X log (Vout/Vin).
Example: Vout/Vin = 2 would be the same as Vout/Vin = 20Xlog2 = 6 dB
People sometimes get confused (or even misled by, due to misconception) by the input sensitivity specification when it simply says 1.2 V (just an example), without any details. That 1.2 V could be based on achieving the rated output that can be anything such as 75 W, 100 W, 500 W etc.., or it is stated for a reference output of say 100 W into 8 ohms, as is often the case for Parasound amps.
The other potential confusion is due to the use of "low" or "high". Example, people may say 1 V is low, versus 2 V, because they are talking about the value, yet 1 V is actually higher than 2 V if they truly refer to "sensitivity" of the amp. To me, it would be more correct, and hopefully more common too, for people to refer to the sensitivity of the power amp, literally, than to refer to the input voltage value, so the lower the input voltage value in the spec would (and should) mean the higher sensitivity the power amp is.
So my question to you: when you said "a higher input sensitivity amp", did you mean the input voltage value, or the sensitivity (literally..)of the power amp? lol..
Hmmmm I get what you are saying, I was asking in reference to your measurements. I was considering purchasing a used Anthem amplifier so I can then have access to use 7 channels.
It says 1.5v for full power with a 29 db gain, MCA 525 gen 1 which is 225 pc.
Since the volts, db, and wattage is different does this change your original computation.
Also just briefly, I have not been into any type of audio until the pandemic. I bought my 7013, my first amp/equipment in September 20’, and I did not purchase my speakers until Black Friday 2020 so basically started using what I had in December so it’s been roughly a year and a half which is about the the time I signed up to ASR.
peng
1.5 V input sensitivity for 225 W is practically the same as 29 dB gain.
Absolutely, volts, dB does the same thing mathematically if you know the math and if the manufacture states both the volts and the output W like Anthem did.
Since the calculations I did for you based on the information you provided were also based on 29 dB so the required pre out voltage for your AVR will be the same if you go with the MCA525, as long as you don't need go exceed your power amp's rated output that is 120 W into 8 ohms for the Denon POA 8300.
You only need 1.5 V if you crank the volume up to the point the MCA 525 will output 225 W.
I understand you may not have a strong background in the EE theories and math needed to understand some of the audio specs. There has been many posts on this so it may be time to summarize some of my responses to your questions.
Input sensitivity is typically stated by manufacturers in several ways such as the following (I am using 1 V in the examples but it can 1.2, 1.5, 4 V or whatever):
1) 1 V, without saying anything else so you have to assume it is for the amp's rated power output, or something else. Examples where it is stated this simple but vague way: Some AVRs, such as Denon, Marantz, Yamaha, Onkyo, Anthem.
2) 1 V at 28.18 V output into 8 ohm, that is a better way but you have to understand that the maximum pre out voltage you need for this amp will depend on the power output you need. 28.18 V into 8 ohm will develop about 99.3 W (watts), so if you want the amp to output say about 200 W, you will need about 1.4 V. Parasound used this format for their input sensitivity spec, but they also provide the gain in dB so, can't complain..
3) 1 V for rated power output, in this case rated output generally mean rated output into 8 ohm. Anthem seem to do it this way, such as 1.5 V for 225 W, and 225 W is their rated output into 8 ohm, for the MCA 225, 325 or 525 amps.
4) Gain can be specified in multiples such as 10, 20, 28, or in dB (logarithmic) such as 10, 15, 26, 29 dB etc.
5) If you know the gain, you can calculate the input voltage, that is the preamp output voltage, required to drive the power amp to output its rated output (Watts).
http://www.sengpielaudio.com/calculator-FactorRatioLevelDecibel.htm has the formula you need.
6) Conversely, if you know the input sensitivity, stated in x volts input for the specified output (W), then you can calculate the gain.
7) The 0.7 V that Amir highlighted was the pre out voltage of the SR7015 that resulted in the highest SINAD achieved.
8) Just because the SR7015 (presumably your SR7013) perform the best in terms of SINAD at 0.7 V does not mean it can only produce 0.7 V. As you can see from the curve, at 2 V it still managed better than 75 dB SINAD, that is about as good as the so called separate prepro, namely the AV7705. It most likely can output higher than 4 V before "clipping".
9) The rms voltage of a music signal varies continuously, unless it is a test tone like a 1 kHz sine wave. So yes you can set the master volume on the SR7013 using a single tone (example: 1 kHz, or 2 kHz...) at a fixed input level, say 30 mVrms (0.03 V). If the input signal is a real music signal, then at any fixed master volume setting, such as -30, -20, 0, the output signal of the preamp, that is the so called pre out voltage, will vary with the input music signal. For example, if you connect a voltmeter to the pre out, set to master volume to say, -5 and observe the pre out voltage, you will see that it goes up and down continuously with the music signal. If the music is at its quietest moment/passage, the pre out voltage could be very low or 0 during the gap between tracks, and at its loudest moment the pre out voltage will be very high.
Point 9) is where you apparently got the misconception.
Let me know if this is clear now or you have any other specific questions related to this topic.
MacCali
I will definitely refer to this in the future. Hopefully the equipment I purchase will not even need this with provided measurements.
Yea this AVR is a bit tricky with a bell shaped sinad
Possibly my final question would be and maybe more simple or far more difficult to answer is would there be a way to upgrade the internals to increase the output stage?
Is it even worth it?
Would it even change the measurements or increase sinad to 2v?
I know this one maybe a very technical question.
Like I said previously, I am pleased with the unit and how it sounds since I have very little knowledge of what a higher measuring AVR can produce audibly. Trying to understand what I need for the best performance when I get that 4K player since the 7013 will be the bottleneck in measurements
Clearly it will be better with a dedicated player vs the nasty compressed audio from streaming, but I mean clearly we are all here to get maximum potential measurements and keep our wallets happy.
peng
There are always ways but a) you, or whoever is going to do it, have to know how. What you have is a 11.1 channel processing capable AVR, so imo, not worth it. You may be interested in finding out if you can hear the distortions from 60 dB SINAD, before you worry about your AVR's 75 dB SINAD at above 2 V output.
Obviously SINAD is just one thing to consider, there are other factors that could be more annoying than the distortion part of the equation.
It isn't that technical at all but it is hard to answer such open ended questions, too many variables at play!
Not all streaming audio are compressed, though the streaming service that provides uncompressed ones are typically paid services. Talking about that, I believe once to get pass the point of diminishing return on devices such as the higher mid range AVRs, or AVPs+power amps, and speakers, you will find that it is far more cost effective to spend on acquiring media contents (including those from streaming) that are of high quality recording/mastering than to chase the electronics.
MacCali
Also figure that’s going to be costly and probably void the warranty possibly.
Honestly man, I am on here because I am very much for measurements. But as I point out on other threads I think people fully comprehend measurements.
I mention is my consistent repetition that you can easily assume that something with 80 db sinad is good sounding since in my experience I own an amp which has a sinad of 40. It was measured by Amir, and he even said I believe in the review or comments it’s one of the worst measuring amps he has ever tested.
Yet, before and after knowing this even with such a poor performance you would assume it sounds horrible, right?
Oddly I enjoy listening to it, this has very much perplexed me.
My main listening setup is world class measurements. So I get what this provides and do appreciate it very much. But even with being able to compare the two I do not feel that I don’t want to listen to that poorly measuring amp in my secondary setup
peng
He also measured the ACA 5W amp designed by Nelson Pass. I had fun building it and thought it sounded great too if I use it with my KEF R900. When I tried it on my little KEF L50, it is almost not listenable unless I used it with a subwoofer.
SINAD of that thing is even less than 40 dB, more like 31 to 38 dB depending on the output and load impedance.
Placebo effect is real so yes I feel the same way. I have been telling you in your application you shouldn't have to worry about the 75 dB SINAD at 2 V but why do you think I replaced my AV8801 (a Marantz prepro) with a Denon AVR-X4400H? There is no way I could tell the difference between the too in terms of sound quality, not even music. The only audible difference is the noise level. The Denon is practically silent from my even if I turn the volume up to +18 (max.) at less than 1 ft or a little further if the HVAC is off. The Marantz could be heard (same speakers) from my mlp that is 10-11 feet if I crank the volume to approach 0, say from -10 and higher. It didn't bother me as I never listened to anything at higher than -10 anyway, usually between -30 and -15 (rarely that high). So I understand why you want your amps and other devices to have the best possible measurements, me too. It is not about audible or not..
MacCali
I seen that one before, I think it’s neat to do DIY. Think they have an assembly video on YouTube. I really prefer class A sound and wanted to buy those, but all my speakers are pretty low sensitivity and 6 ohms so I decided to pass in an effort not to waste money
Again though, it may just be delusion but just hoping that when I get my 4K player it will be a massive improvement since everyone is always talking all this and that about blu ray players. Just particularly in the sound department.
I literally don’t even have enough free time throughout the day to go to the actual movie theaters even before covid. So really trying to maximize the experience.
Appreciate all your input, feedback, and effort.
peng
Any time, good to know it helps..
By the way, I don't remember if we have covered the one thing you can do to improve SINAD for the pre out (on paper anyway) if you use the amp assign feature to disconnect the front left and right channel internal amps. It won't help as much as it can on Denon's but still can improve by a few dB (5 dB at 2 V) as shown in the graphs SINAD vs output voltage for the SR7015 and SR6014. The SR7013 should be comparable to that of the SR6014 as the it was launched only 1 year before the 6014.
D
Deleted member 50971
Guest
@amirm A bit late to the party but thank you for this review.
Is the slow filter used for the DAC audible in your opinion?
MacCali
I think it basically lets ultrasonic noise leak through the speakers, but I’m not sure what that means since you can’t technically hear above 20k.
If I do recall it may do something like overload your tweeter, but honestly can’t say for certain I am not an expert
Hopefully someone will reach out that’s more knowledgeable
peng
I recall someone posted on that too but I highly doubt it would overload your tweeter as such even in the worse case scenario (may be possible under some special conditions). One would think that the typical tweeters voice coil itself would have enough inductance to limit current at the supersonic frequencies too.
Take a look of the following from the AK4490 datasheet:
I am not 100% sure which one Marantz used but I seem to recall reading it somewhere that it was the short delay slow roll-off one. Either way, I don't see enough energy much pass the audio band limit of 20 to 24 kHz.
peng
Good morning/afternoon. I think at some point I may pull the trigger on this unit, and well not perfect in my experience they are a very stable preamp. Yes I would like for them to measure a little better, and deep six those hdams, but this is about as much as I want to pay for an AVP.
The only thing stopping me is it will look exactly like my current one, and I would like to get it for around $4000 instead of $5400. Denon? I need XLR out, and prefer an XLR in. I’ll wait one year, and see how I feel.
I am in the same boat on this, but if in a year the AV7707, or whatever would measure as good as my AVR-X4400H I would likely go for it instead of the very expensive AV8806/08. Otherwise I may just bite the bullet and get the AVM70. The Anthem seems all good except no 8K (don't need it but seems like matter of principle that it should be there), and I am too used to Audyssey and Dirac but remain a little skeptical with Anthem ARC. Also am more confident in D+M than in Anthem that I don't think is as well equipped to deal with the sophisticated AV processors.
MacCali
Honestly at this point the 3700h seems to do good as well as any of those denons with higher sinad.
I think you will obviously get better crosstalk performance and sinad if it’s shooting out 4v. But the 3700 at 101 @ 1.1 1.2v seems to be very legit. The only thing is it is missing a few of those newer codecs. Really depends how important those are to you.
Also something to consider is how many channels you got.
I see that many reviewers would advice that going 7 channels vs 5.x.2 is better. That Dolby isn’t as good without more channels. 7 floor channels is far more immersive, not sure how valid those statements are
Reason why I mentioned the 3700 is it’s on the denon website for 1000 atm refurbished
peng
What do you mean by
What do you mean by shooting out 4v?
peng
Isn’t XLR output to the amps 4v typicall
Not really, Amir typically test preamp's unbalanced RCA outputs at 2 V and balanced XLR outputs at 4V. That's just for the bench tests to measure performance at that output level.
Obviously, the actual output when in use will not be at a fixed level as it will depend on the input signal and the gain of the preamp such that it will vary from 0v to a maximum of several volts to even more than 10 volts depending the preamp's design. For the AV8805, the maximum will likely be about 8 V from the XLR output.
peng
Heres a big variable in all of this… room correction. I know everyone believes that Dirac and Anthem are superior to Audyssey, and I’ll concede that they may be, although I do not have any experience with any other one except Audyssey.
Amir reviewed audyssey multeq xt32 very favorably, and ever since room correction enter the AVR/AVP world they’ve been a game changer. Although during movies I like to run my subwoofers a little hotter than suggested, but that’s pretty easily remedied.
Are we really going to hear a difference between an AVR/AVP with a SINAD of 85 and one with 100 SINAD after room correction is applied?
How about for 2-channel and multi channel music listening?
I doubt we’d hear any difference but that’s just my opinion. so then it comes down to features and stability also in my opinion. I’m familiar with the Marantz/Denon platform and one thing I know… It just works day in and day out. Yes they all have glitches, but they are the Swiss Army knife of home theater and music listening.
This being said I would love to get to 100 SINAD with a new Marantz AVP and call it a day. For the sake of good engineering hygiene, and the satisfaction of knowing Marantz was willing to raise the bar. Who doesn’t like well measuring gear on this forum?
For audibility of distortions, I am of the same opinion more or less. For noise, as Amir said before, you will hear it. Even then, I could hear my AV8801 hiss/hum but only at volume >-10 or so and even then it would still sound silent from 10-11 ft if the HVAC on though I still fee good about the Denon that is silent unless my ears are within a couple inches.
I disagree with the part about everyone believes that Dirac and Anthem are superior to Audyssey. To me, Dirac likely is, but not sure about Anthem's. May be every Anthem ARC users believes, but for those who have used both, may be not (again, key word "everyone, may be some do , some don't).
I admit I am a little biased, and I don't like their apparent approach of sticking with IIR only filters vs Dirac's mixed (FIR and IIR) and Audyssey's FIR only. Also, I wish Anthem is less secretive about their "ARC", I don't need them to tell us everything, but there just isn't much technical information about their system and approach. All I can see are mostly marketing blurbs, such as telling Audioholics.com in an interview that: "It works! Listeners prefer ARC on vs ARC off. We don’t hide behind pseudo-scientific explanations, and apparently other companies are slowly gravitating towards our approach as they can test our system and see for themselves that it works." Implying other's were pseudo....., when they didn't even try!! Just take a look of their owner's manual for their AVP/AVRs and compared that with Denon, Marantz, Onkyo, Yamaha's. Anthem's 70 pages cover to cover that covers every single model of their AVRs and AVPs, every time I wanted to know more about their product I got disappointed. Sorry I digress..
