iviardo
I'm interested, too, but I'm afraid of getting lost. Please don't forget to leave a link to the stream.New thread. Posting from phone so short replies.
Sorry for additional questions, if you don't install drivers, will dsd files be read as well?Do not install any drivers. Just plug in and it should all work.
Having 35-40C is usually normal during the mid summer here at my place, but contrary to that this year we are having lower temps and lots of rain.
Up to DSD 256 using DoP (although I have not tested it). Otherwise you do need to install drivers.Sorry for additional questions, if you don't install drivers, will dsd files be read as well?
Per request, I ran a couple of quick tests against Topping D30. Here is the Jitter test:
So the Topping D30 is superior here due to absence of those jitter spikes.
On the other hand, I did a quick test of linearity and the D10 is better actually.
Can't make a case of audibility though so I still say purchase based on features/budgets you have.
From my perspective this says the D10 is not a mature product, yet.Topping support states they're working on firmware to solve the "USB interference" for the D10, like they did with the D50 and DX7s. Fingers crossed ^^
I also agree with you.From my perspective this says the D10 is not a mature product, yet.
Firmware of D50 and DX 7s was updated several days ago, but it has not been completely improved and there are still some problems.
Mulling this over:
Budget: $30 difference is not material.
Features: I use dsp for bass management, so all DSD is converted to PCM 352.8 first. That gives some utility to the D10's higher PCM capability although resampling down to 172.4 probably will not hurt anything. The display on the D10 is likely to become a distraction.
The D30 seems to have a following. Posts regarding the D10 are scarce outside of the Massdrop thread, but it hasn't been around as long.
Anyone want to shine some light on this question?
What is the USB interference you are referring to?Topping support states they're working on firmware to solve the "USB interference" for the D10, like they did with the D50 and DX7s. Fingers crossed ^^
It's somewhere back in this thread. I seem to recall the solution was a customized USB cable where the power leads were connected to a 5V source separate from the computer supplying audio.What is the USB interference you are referring to?
