Topping D10 Balanced Review (USB DAC)
kchap
Melbourne, Oz
Baby steps on my part. So how do you feed the output of DAC back into REW?
Blumlein 88
I am pretty sure I know nothing about measuring distortion. Everything I measure is showing crazy digital distortion.
Here is how I measured the Topping (probably wrong)
1. PC---REW 1k sign----Zoom h6 at -18dbfs----REW RTA on spectrum on another PC
So doing it this way the topping results with a clean signal at -13.3dbfs then it goes bonkers with digital clipping at only -11.9dbfs
I have this same problem with all the DAC's I am testing so it must be my problem. but the mini DSP doesn't go crazy until-6dbfs
the clipped screen grab doesn't show all the data, but you can see what looks like straight up digital clipping.
I tried this with and without the topping drivers and swapped computers to see if issue remained. thanks for any help!
Have you calibrated the Full Scale level in REW? You need it so that 0 dbfs or -1 dfbs registers as that in REW. I'm not familiar enough with the Zoom to be of much help on whether you've set it up optimally. I think from memory that close to 0 dbFS is 4.25 volts with the DAC 10 balanced.
GimeDsp
Earth
I checked the REW output level with my normal loudness meter for production, and also exported a wav file of same to check in audacity. All meters show REW output matches. I changed REW to "show full scale as 0dbfs". Thanks.
kchap
Melbourne, Oz
Going to the web, the H6 max level in is +22 dBu, around 10 V RMS. I imagine 10 would be with the pads switched in.
GimeDsp
Earth
I ran the gain down pretty low and it gave me a good signal at -18dbfs.
kchap
Melbourne, Oz
Fat fingers!
Going to the web, the H6 max level in is +22 dBu, around 10 V RMS. I imagine that would be with the pads switched in.
So you a need known good test signal of around 14.7 dBu, 4.2 Vrms to confirm that you are not overloading the Zoom.
GimeDsp
Earth
RESOLVED
Thanks for taking the time to help me trouble shoot! I'm a studio tech grunt and subjective system evaluator and don't have time to learn a lot of things.
So just to see if it made a difference I ran the signal out of my miniDSP dac and into Zoom H6 on the same PC.
This stabilized everything and I got a clean signal as expected. I am not sure why that is but am sure some REW person would know.
Below is measurement of miniDSP ddrc-24 showing what it should look like with a 0dbfs signal output.
GimeDsp
Earth
Used the d10 balanced in pro audio set up today.
Plugged it in and it was recognized instantly. Used the balanced line in on a Allen & Health mixwiz16, engaged the 20db pad and the mixer's gain dial had to be put really low. This thing has a strong output!
Only used one side of D10b output, mono into mixer and it sounded and worked great.
Even in an environment where hum/noise has been an issue the D10 balanced was silent.
Thanks to topping for making a good variety of nice gear!
pseudoid
... I look forward to the day when record executives are banned...
You should have stopped after that last word.
These kinds of 'shenanigans' bankroll the 'HooliganBastards' lifestyles and will never stop! All the while studios and sound engineers have become endangered species like the recording artists.
Ingenieur
PA
Mine arrived today
Hooked and playing
So far, so good
Using adapters XLR into 509x
1/4" to male XLR cables on the way
Downloaded their drivers:
Listened to 'default ASIO topping usb audio device' and 'default speaker/topping usb DAC'
I think I like 'speaker' better.
Is there actually a difference? Or am I imaging things? lol
Rottmannash
Nashville
Mine arrived today
Hooked and playing
So far, so good
I think that's just how it's labeled. Mine says the same thing on Win 10/Audirvana.
pseudoid
I am still having issues with the 1/4" jacks: Ultimately, the required adapter cables will end up being XLRs (in most cases). This adds to the overall cost AND unnecessarily complicates interconnections.
GimeDsp
Earth
What issues are you having?
Rottmannash
Nashville
Hart Audio Cables has a nice set of interconnects that will work for the E50 or D10 Balanced.
Ingenieur
PA
I ordered these x2.
I was listening today, the D10B brings out a lot of detail. Soft cymbals, drum stick taps on the rim, etc.
Blumlein 88
I ordered these x2.
Yeah those guys make very nice cables with good components for not a lot of money. Available in any configuration you can imagine as well.
Walter
$45 cables apparently specifically designed for a $130 DAC. Sigh...
Rottmannash
Nashville
