Topping D10 Balanced Review (USB DAC)
nyxnyxnyx
Are there any audible differences or improvements between this DAC and some dacs on the absolute top of the scoreboard?
I don't care much about functions or aesthetics, but I want to see if spending extra for a D70/D90 can be a good improvement on what aspects...
usern
You pay for functions and aestethics. More outputs costs more (XLR + RCA), more inputs costs more (SPIDF coax, optics). Bigger enclosure costs more. BT and its codecs, MQA, powersupply all add to the cost. But they all sound transparent, practically same. Don't buy D10B for amp with only RCA inputs though.
Veri
It doesn't get much better than D10B. Unless you seriously need something of the bigger brothers, probably not worth the cost IMO. DACs are not complicated ;) stack aesthetics also matter to many people though.
Toku
Japan
I thought D10s has such feature and it is builtin ESS DAC chip. Am I wrong?
You are misunderstanding about the D10 series products.
The D10 series is a product made for a specific application and does not have the same functions as other DACs.
Choose a DAC other than the D10 series for the application you envision. That's the shortcut to making you happy.
tmo
so cool to see this kind of value for a DAC. :eek:
can anyone recommend an amp to go with this?
HDavidson
miofu
I'm misunderstanding D10 series? So why other D10 series models have such a function?
https://www.audiosciencereview.com/...how-to-make-topping-d10-act-as-a-preamp.3687/
Here on linux, access from amixer:
http://moodeaudio.org/forum/showthread.php?tid=1970
JohnYang1997
China
JohnYang1997
China
I've read whole topic on http://moodeaudio.org/forum/showthread.php?tid=1970&page=2
So those guys are thinking that are using hardware, but thay not? :D
Alsa with hwplug option does not provide any software volume.
There are three scenarios:
1, The player has functionality to change volume via digital processing on computer.
2, The OS/driver talks to XMOS to change volume in XMOS chip which is USB bridge.
3, The DAC itself has volume control which changes registers in the DAC chip.
First two are possible with D10/D10s/D10 balanced.
The result at the DAC analogue output can be identical if either process itself is done cleanly.
In fact, when doing measurements all attenuation is done in the AP software via ASIO. There's no measurable degradation comparing to change volume on DAC itself. At least for all PCM sources.
jawbfl
Morocco
They look really good! For a moment I thought they were the ones shipped with the D10B and was mistakenly impressed :p
Me too at first, but that cable looks as flexible as a Mogami so it won't be cheap.
deprogrammed
Dayton Ohio
I miss the coax in. So will many others.
One reason I bought the D10 is the coax out. Used it to connect my PC to a receiver.
jawbfl
Morocco
lol! i knew something was up.
my question still stands though. :)
Good concept but I doubt Topping would make it, D10, D10s never had a companion amp.
hyperknot
How does the XMOS chip change volume? Just adjusting the digital signal before the DAC?
Would an audio player have higher quality volume control compared to the XMOS chip?
