I just ordered one from Apos.
Yes, but being 6.3 mm jacks they can take the weight. It was all I could get on a Sunday. I have 6.3 TRS to XLR male cables on order.You connected the adapters to the xlr M to F cables, right? Must have been quite extended at the back of D10b, right?
I ordered mine through Amazon. I was using a Khadas Tone Board which performs well but I could not resist the D10 Balanced. The Khadas does generate a loud burst of noise during "power on" and "power off" so I need to be careful not to switch on the amps until after I switch on the RPI. The D10 mutes its output during power on and power off; an unexpected bonus.I just ordered one from Apos.
My D10 Balanced is now on a plane from China to Japan.I ordered mine through Amazon. I was using a Khadas Tone Board which performs well but I could not resist the D10 Balanced. The Khadas does generate a loud burst of noise during "power on" and "power off" so I need to be careful not to switch on the amps until after I switch on the RPI. The D10 mutes its output during power on and power off; an unexpected bonus.
The Khadas and another RPI will drive a HP amp when I replace my very old Stax SR-5.
I have a RPI 4 with a D10 balanced DAC and it works very well.I'm wondering if a RPI 4 is able to deliver enough power to the D10 balanced DAC and if the audio signals from the RPI will suffer while the Topping draws high current from it?
I have the 10s, I feel like buying 10b for the purpose connecting to ifi zen can..... dunno if possible.....
I already have the pentaconn 4.4mm male to 2XLR female jack cable so I can then use the adapters provided with the d10b, connect them together and then connect the d10b to ifi zen can.
Just what I expected from an ASR member .. sometimes I just need to hear some flowery talk.Just the same as any other DAC.
I'm satisfied.The rhythm and pace is more 'balanced'.
Haha...sorry to disappoint. I did talk flowery once but after I went through the sighted but volume matched test...the DACs do really sound the same. Having said that from my personal experience I do value DAC that have more power ie more than 2V out ot RCA and more than 4V out of XLR. They do make the amps that get these extra voltage have more volume headroom. That's what I experienced.Just what I expected from an ASR member .. sometimes I just need to hear some flowery talk.
Any reliability issues though?
Good to know, my brain still refuses to accept that all good measuring DACs are equal. Any issues with ESD or something of the sort?Haha...sorry to disappoint. I did talk flowery once but after I went through the sighted but volume matched test...the DACs do really sound the same. Having said that from my personal experience I do value DAC that have more power ie more than 2V out ot RCA and more than 4V out of XLR. They do make the amps that get these extra voltage have more volume headroom. That's what I experienced.
You can check my thread here
If you mean the reliability of the D10b, so far ok... It's USB behavior is a bit different from D10s/D10. One of my usb hub (to add external power to the DAC) seems not to work with this DAC but connecting straight to DAP does work... I have to experiment more why this is so.
Cool! , Can't wait for mine arriving soon in 2 days
Depends on your use case and wishes.Hmm this or D30 Pro.........
