Topping D10 Balanced Review (USB DAC)
gasolin75
Denmark
They sound identical to me.
The topping E30 has filters so it should sound different using the filters, also i think noise,gain could make a difference on the D10 Balance since gain is higher and noise lower
Rottmannash
Nashville
If you can hear a difference between the filters then your auditory discernment tops mine. They are both transparent so shouldn't sound different, if levels are matched.
gasolin75
Denmark
Higher gain, lower noise, less RFI,inteference if you use balanced cable with the balanced dac when you have a ton of cables or have to have super long + 10 meter long cables or both
Topping E30
gasolin75
Denmark
balanced are often used in studios or at live events with alot of super long cables
If i didn't mention it i have a Topping D10 Balanced
NeoZs99
Is it possible to use a "normal" xlr to rca cable since my sub has only rca inputs?
gasolin75
Denmark
yes, the same with active speakers you can mix and match what ever you have, but theres no sub out on a Topping D10 Balanced
NeoZs99
Thank you.. it's stereo input into my sub and from it's output to my active speakers
gasolin75
Denmark
Oh not excatly Topping D10 Balanced related
You can mix and match what ever you prefer, xlr to xlr or xlr to trs/jack or rca to either trs/jack or xlr usually cost the same 15-20 euros or dollars for a pair, not that expensive even in a 3 meter version
gasolin75
Denmark
If you read the datasheet of D10 balanced, there is a warning that adapters to single-ended are not supported.
It's stereo into the sub, should work
Veri
Like Atanasi said, you shouldn't go balanced to single ended. The D10B is not meant for that, performance will be severely degraded.
gasolin75
Denmark
it's not super expensive buying the right cable
what is the speaker volume controlled with ?
gasolin75
Denmark
Rottmannash
Nashville
NeoZs99
Thank y'all.. though I guess would work if I connected them directly to my active speakers. In any case I'll get the d10s or e30
